  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Paul i know i cant compete with them ....... im sorry i just cant give you that kinda fat! I know im not as enjoyable to eat..... i'll just try to aim for a little more my league ...... Jarrod from Subway :(
