  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Guys, how much do you think is a good price to sell a GTR wing for ..... it'll be in top condition .... cos ive just decided to get the panel beater to fix it instead of this shit and then this fibrevision guy seems rather cheap so it'll probably only cost me an extra $200 tops to get it done properly.
its black .... the one off my car :P
Bam i dont know ....hopefully before PAS but i have a feeling like all panel beaters going to be screwed around and its going to take longer. I'll get my dad to talk to this guy .... just messaged dad now and told him to phuck the pursuit of a veilside wing out of him just get him to fix mine and my wing should be fairly easy to sell .... and i'll just chuck an extra $200 - $300 and get it done properly!
bam - was asking wht you were peddling and why.
coming for dinner on monday night?
snyper - I would probably by dave (REV210)'s carif I were in the market - especially if it's been fixed with forgies and seeing as how he needs to sell it for a given price, I think it'd be a bargain..
nothing wrong with Adrians car looks sweet!! ..... saw him going to work the other day along Welshpool Rd but didnt bother waving cos i was in Laser and he wouldnt of recognised me :P
Godfather ..... I know somebody in Osborne Park .... but nobody in Welshpool ..... C-Red dont do it.
hehe i called you Godfather instead of Bam ..... sorry was in La La land :( emailing Liz .... she bought boost gauge for her car a while back just checking if she still has it or did it end up in her car ..... she still has it :P yay.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
