240Z (ooooh another Zed lover ..... i love my Zeds :D ) mines not entered this year tho it should be up front of carpark this year ..... it stopped traffic (literally) last year when i rolled up in the carpark .... basically had to wipe drool off it...... but im hoping mine will be worthy next year ..... plan to do quite a bit of cosmetic work to it :D
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah i dont have the money for widebody ..... i dont have the money for a tin of baked beans at the moment .... but i think i would go mechanical work (go fast bitz) before i did widebody.
do you have pics Aidwin??
i just want to know which one im getting when i ask for Veilside wing ..... i think its the first one as its the only one thats featured on Fibrevisions website.
agree, wide-body does cost lots. like the look of the white R33 GTS-T at last years PAS with the wide-body but!
have you guys seen pics of my 240Z? here is a link to some
http://www.skylinesaustralia.com/forums/sh...t=RB26DETT+240Z
Steve @ SST want me to bring it to PAS for SST trade stand but its not yet finished...
240Z: i own a Z31 300zx ....... ok so they look shithouse on the street but you havent seen this one :D i'll post pics in a moment .... i love my baby and its faster than the whale :D and my evil parents are about to sell it!! I was originally going to get a Z32 ...... mmmmm with 20 inch rims .... but they are hard to work on and apparently a R33 is going to be more "cost effective" .... still :drooling: everytime i see a Zed tho!! I love Skylines ..... but my first love was always Zeds!! & you never forget your first love :D
Dan: FREE .... but they cost about $720 painted and fitted new ..... dad got a price of $730 when he rang ..... when i rang i got a price of $620 :confused: so i dont know ..... but who cares!!
yeah zeds are a top looker, I love lots of cars but have a soft spot fo a nice zed... would love to see your Z31.
But I like 240Z...skip skip...then the 350Z! (one day the 350Z will going the garage, but after a house)
sold my 911 to fund the project, so that has to say something!
Z31 are ok too, the 200ZR version is the pick of the crop for that shape as they came with RB20DET from factory, which means that a RB26DETT conversion is a natural progression for it :D
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
