  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
cant we tow Aidwins car in :) haha it only has to look pretty!!
pity my rear bar wont be done by PAS .... then all we would have to do is swap Aidwins carbon fibre bonnet with my bonnet for the weekend and i could be an aidwin look-a-like without all the go fast bits ..... but hey with a carbon fibre bonnet who would want it up anyway?
