  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Paul,
Tune is now put back to Friday!!!! Due to other issues with tuner... My car will be finished tomorrow night, even got the new fuel reg in too!! Remind me to tell you the deal I swung with em, it's pretty damn good if you ask me....
So fingers crossed for friday morning, I'm getting on the dyno first so should be done within 2 hours... Then clean and get ready for action....
Have you heard from Lloyd??
Originally posted by GTS-t VSPEC
Danny/Brett, I have the spec sheets now, will try and get them colour printed and laminated tommorow, they look good:D
COOL, do we get to have a sneeky peek at them or do we have to wait until Friday. Did you get the vinyl from WA Salvage yet??
The info coming from Lloyd is BAD, not a good way to do business, maybe the work load is huge for him. Oh well
:headspin:
Trust me Paul I'm not happy about leaving it till Friday, waaayy too many things can go wrong leaving no time to fix them..
Anyway I'll be free friday and probably thursday cause I have to get the stereo put back into my car so if you need anything done let me know..
Just tried Lloyd and he's not answering, left a message.....
Brett, No worries, I'm taking both days off too.
This is the quote from snap printing.
6 Digital printing in full colour, taken from disk or email on 1/side of A3 100gsm 4cc gloss paper. All laminated.
Sub Total 39.82
GST 3.98
Total 43.80
What do you guys think? Is A3 too big?
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
