  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Paul you are awake that time of the day :P much to the annoyance of people like me that like to sleep in.
Dan - im a Tree Hugging Hippy ..... last time i went to Queensland there was actually hippy's hanging outta trees everywhere .... :werd:
Originally posted by GTS-t VSPEC
Brett, No worries, I'm taking both days off too.
This is the quote from snap printing.
6  Digital printing in full colour, taken from disk or email on 1/side of  A3 100gsm 4cc gloss paper. All laminated.
             Sub Total          39.82
             GST                 3.98
             Total              43.80
What do you guys think? Is A3 too big?
paul,
that's ****ing bogus bra!
email me the sheets and I'll colour A3 print em. then you can get them laminated at officeworks for like, **** all.
I have the red skyline hatch if required. fitted my tv (in the box) into the back.with the seats folded down.
yeah - im getting there haha .... was going to do it tommorrow but thought i better type them up while i still have some memory of whats said.
And while whoretown is quiet ...... Bam hasnt been in today :P
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
