  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah cos a few of us are comming from the Cannington area it shouldnt be hard to get together a taxi/maxi taxi for the way out ..... so it should work out cheap. :(
Long time since you gone clubbing Aidwin - yeah me too its been like ......2 months at least since ive been into Northbridge!!
It was taken back when i was 15 :( .... just before my 16th Birthday .... that was taken in the studio ...... there rest were in Allendale Square in the city (was wearing a $500 cargo dress!) and Forest Place .... i dont have the ones from Forest Place - my old agent has still got most of them .... or chucked them by now .... who knows.
Aidwin .... when it comes to Barstaff theres a secret hun .... my ex taught me how to attract barstaffs attention really well - you dont even need a set of boobs to do it ..... although it helps. When we are at Metros i'll show you how to do it hun :)
    • Photo quality is terrible, but there's a few things on that board that give me suspicions it has some issues. Add to that, I'm hoping the cut and exposed wires under the dash were not exposed or touching each other before you pulled that all apart.
    • Stories like this are why the immobilizer installs I've done are 100% reversible. No harness cuts.
    • update; Replaced oem starter motor with a Jaylec 70-61111 car still didn't start, moved over to the alarm system unraveled the spaghetti checked the solder end points, PCB board burn smell, wiring ends, capacitors, water damage everything looked fine restarted car vroom. restarted 5 to 6 time over an hour started put every thing back together only to not have it start any more. looks like i will be removing the alarm system next weekend.
    • Lots of people. Could be a lot of things like people have said. Either the heater hose/pipe, the turbo coolant return that wraps around the back of the engine, or a core plug. I have seen all three. If you want me to guess wildly though I would bet it's one of those hoses for the turbo coolant return. Or the brazing/welding for the Y- section has failed. Get a borescope down there to be 100% sure.
    • FWIW, I've aerated oil, and cams snapped. You can figure out the rest 🥲
