  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah cos a few of us are comming from the Cannington area it shouldnt be hard to get together a taxi/maxi taxi for the way out ..... so it should work out cheap. :(
Long time since you gone clubbing Aidwin - yeah me too its been like ......2 months at least since ive been into Northbridge!!
It was taken back when i was 15 :( .... just before my 16th Birthday .... that was taken in the studio ...... there rest were in Allendale Square in the city (was wearing a $500 cargo dress!) and Forest Place .... i dont have the ones from Forest Place - my old agent has still got most of them .... or chucked them by now .... who knows.
Aidwin .... when it comes to Barstaff theres a secret hun .... my ex taught me how to attract barstaffs attention really well - you dont even need a set of boobs to do it ..... although it helps. When we are at Metros i'll show you how to do it hun :)
    • FWIW, I've aerated oil, and cams snapped. You can figure out the rest 🥲
    • Depending on the hose, sometimes engine out is the easiest option
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
