  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
A bus stops and two Italian men get on. They sit down and engage in an animated conversation. The lady sitting behind them ignores them at first, but her attention is galvanised when she hears one of the men say the following:
"Emma come first. Den I come. Den two asses come together. I come once-a-more. Two asses, they come together again. I come again and pee twice. Then I come one lasta time." "You foul-mouthed sex obsessed swine," retorted the lady indignantly.
"In this country....we don't speak aloud in pubic places about our sex lives.........
"Hey, coola down lady," said the man. "Who talkin' abouta sexa? I'm a justa tellin' my frienda how spella 'Mississippi'."
I BET YOU READ THIS AGAIN!!
OK, TO ALL THOSE USIN A MINIDV CAM'S USE A TRIPOD WHEN ZOOMING INTO DETAIL.....LOTS OF INTERLACING PROBLEMS AS THE CAMERA IS DIGITAL IN MECHANISM BUT THE TAPES ARE STILL PART ANALOGGGGGG......
AND USE PROGRESSIVE SCAN....
EVERY FRAMEX2 FOR QUALITY.....
JUST A FEW THINGS TO THINK ABOUT WHEN TAKING A FOOTAGE FOR A DVD IN THE FUTURE......
AGAIN EXCUSE THE CAPS I AM RENDERING......
    • I refer you to this thread on PF, by someone who knows what he's doing. Paints a good picture of the humble AD09.
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
    • Semi slicks are horrible for road use, just use a high performance road tyre unless you really need the maximum grip. Noisy, unpredictable (amazing, until they are not), expensive due to very high wear and not good in cold and particular wet. And yes, it is a thing to store cars on stands instead of tyres if you know they are going to be parked up long term.....but who ever realises that a short park is going to stretch into years before it is out again!
    • I know in Australia you'll definitely get above 30c. Parked in the shade in Summer you'll be above that. 😛 But in cooler climates, you might get that warm driving on the highway for a bit, but you'd never get to full heat temp. I'll try and find some of my historical tyre temps between Aus summer and winter (be aware immin the warmer area of Aus too.)
