  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Boosty - where theres a will theres a way :)
haha yeah it was funny when i lived outta home ...... the ex thought my parents had too much control over me .... my parents thought the ex had too much control over me and there was this constant tug of war for my attention .... it was pretty stressful at the time but now i look at it - it was kinda funny. ;)
U sound like quite the commodity there Niz.
I still live with my parents and while it does drive me crazy at times, its all good. When i get mom and dad asking me questions and moving my stuff i kinda get close to losing it. I think all ppl our age that live at home do.
Parents went away for near on 2 months a while back and left me and my big bro who doesnt know even how to work the washing machine and my little sister who is not too bad but a bit of a slob to fend for ourselves.
I loved it, couldnt get enough. The regime of Shaun had begun. Eat what i felt like (i cooked the meals) kept the house spotless and basically did as i liked.
After they got back i alomost had a breakdown but now its back to normal and ive come to accept the norm.
Basically id move out but its too much fun having no responsibilites.:uh-huh:
Well actually moving back in with mine wasnt so bad - cos they appreciated me more - and they werent there half the time anyway (in bunbury) and so it was just me and a mate of mine had the house - so it was basically like still living on my own ..... and when they did occasionally come back to High Wycombe they appreciated me a lot more since id been away and were absolute honeys about giving me my own space etc ..... but now its gone backward quite a bit.
Im hoping this summer they migrate down to Bunbury for most of the summer again and then i maybe tempted to stay.
Boosty - i cope pretty well without my folks ..... my mums always worked so from an early age i was taught to do my own washing and make my own meals etc.
Yeh my mom used to work so ive pretty much done everything for myself. She hasnt worked in a while now but the habit still stuck around.
I guess the old "if u want a job done right do it ureself" theory applies here. My bro is hilarious, he would rather eat 3 serving of noodles a day than make something else. Complete nut job me thinks.
i like making my own meals - i get in a cooking mood ..... unfortunately my mum never had the time to teach me to use anything other than the microwave ........ so cooking was a lot of trial n error haha.
Paul - yeah - still cant believe that we havent had a family Xmas in three years ;) !!
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
