  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
indeedy am i Paul ...... Mels going as a butterfly ...... *embarrassed* little miss raver! im only going cos she begged me too :) so im going to get pissed (first rave ive gone too where ive done that) and i have to be back at home bright n early Saturday morning for the supervision of mum renovating my room ...... with those stoopid 70s cupboards.
Paul - taking Mel to a rave is never much fun ....... im usually the one that has to chuck my fingers down her throat then carry her outside and nurse her ...... and i dont have a guy around this time to help me - which scares me but im sure any situations that arise i will handle at that time ....... but she has a bad reaction and she really needs to leave the stuff alone but i cant tell her.
thanks Lee *big sloppy kiss*
thanks Lee - fingers crossed this should be the first "event free" MoS her n i've been too.
hehe im in a room full of poms. Im 25% irish .... 25% french .... and the other 50% is full on aussie ..... one of them can be traced right back to Ned Kelly and the other to some other murdering villian during convict times ....cant remember name ..... but it would explain why i have bad wrath :)
wheres my links Lee!
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
