  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Pacey dont worry im poor too! the only reason why im getting a veilside rear bar is cos its free.
Cooooongrrratttts Aidwin!! ...... but im not sure your car can get any sexier!
I going to put my GTR rear wing up for sale soon - that sohuld give me some spare cash til i find a job! it was orignally going to be intercooler money but depends how job situation goes.
