  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Kyles
my computer was about to be thrown off the balcony thismorning.
OH MY GOD! its my last night in my apartment... and im alone.. Gez that sucks! lol
i beg ur pardon missy
do u want me to take that puter home again????
and u wouldn't let me stay home and keep u company so i went to work
