  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
that shit is still beyond me.....how can they expect a creative talent to be a coldfusion/oracle expert........
I wnat to debate this with the government.........I must have studied a wrong units .......or on another planet....
ok I am off to get some pills ....
Al about Being A Loser at the End of "He Thought He Could" (302)
Al to Mrs. De Groot: "So you think I'm a loser? Just because I have a stinking job that I hate, a family that doesn't respect me, a whole city that curses the day I was born? Well, that may mean loser to you, but let me tell you something. Every morning when I wake up, I know it's not going to get any better until I go back to sleep again. So I get up, have my watered down Tang and still-frozen Pop Tart, get in my car with no upholstery, no gas and six more payments to fight traffic just for the privilege of putting cheap shoes on the cloven hooves of people like you. I'll never play football like I thought I would, I'll never know the touch of a beautiful woman, and I'll never again know the joy of driving without a bag on my head. But I'm not a loser. 'Cause despite it all, me and every other guy who'll never be what he wanted to be, are still out there, being what we don't wanna be, forty hours a week, for life. And the fact that I haven't put a gun to my mouth, you pudding of a woman, makes me a winner!"
At the Nudie Bar
from Rites of Passage (616)
Where the music stinks, and they water the drinks, the nudie bar.
Where the girlies dance in their underpants, the nudie bar.
Where you see their butt, and their trap stays shut, at the nudie bar.
Where you can't touch a breast, but you can cave in a chest, at the nudie bar.
Where you look at a thigh, and blacken an eye, at the nudie bar.
Where the beer gives you gas, but the Bundys kick ass, at the nudie bar.
    • You need one of those automated sprays that puffs a nice small every 15 minutes in their room. Except swap the nice smell for chloroform...
    • Don't step down power supply size, maintain it the whole way. It's how I'd do it. OR, Id have one feed, with one joint that splits out to six smaller gauge wires that go to each coil. I wouldn't add joins like stepping from 12 to 16, at the first two coils, as if you try to continue that fashion, each joint will introduce a voltage drop. In theory, earths should be the same size as power feeds, however in this case the main power needs to be bigger due to the average size current. So the next question is, how much current do these coils actually need?
    • I think Murray is onto it. It's sounding like either it's a soft block, not long enough block, OR if you're chasing waves, you're going in the direction of the waves, instead of across them. Rotate your sanding pattern by 45 degrees is something to try. You said you're going in an X, so now instead, from the same perspective, do a "t" instead.   If you're not able to have the block sit on top of two high points, and not touch the low point between them, you'll never get it flat.
    • Hi, i’m making Vag coil loom for rb25det, can anyone confirm the wire guage i’m using for power supply in diagram is enough for supply not too small for loom? For earth do i need to follow the same procedure or i can use only 16awg wire for all coil and their connecting wire following to the plug?
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
