  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah front indicator cover is what im after aidwin as mines smashed ..... and the panel beater seems to take his sweet time finding one :( sooo if u got one i can pick it up on way to gym
ours are both series I Aidwin - dont see any reason why shouldnt fit ..... actually might come over after ive picked up car which would be about 5:30pm ..... if the arsehole has managed to track one down & its already on my car then i'll send you a message.
Hi Denver
