  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Dan - when i left Skippers i used to get a call the ex used to ask me what i wanted to drive for the weekend ;) The highest earners got the first choice of cars ..... it goes down the foodchain.
Will change it Milo
Lee: Jeremy is cool .... was at MoS with him once back in the days. He's not up himself whatsoever.
from Skippers Dan? hmmm good question ..... i got the most excited about the Skyline (this is before i had one myself) ...... had WRX's most weekends so they lost their appeal ..... when i didnt have WRX i usually had 200sx ...... im sure ive driven better cars but i cant really remember .... a car starts to become a car after a while. The most fustrating was the Ford Cougar .... Europen indicators on wrong side etc .... trying to drive that home drunk from Northbridge was a challenge. Purple Convertible MG was cute. Oh i didn tget to drive it .....ex did .... Mitsubishi GTO ( i think thats what its called .... twin turbo 4wd number) he reckons he was one of the best cars he's ever driven. Um nearly died in a 300zx going sideways in the wet into the oncoming path of a Hyundai Excel.
He got done racing a porsche up Mounts Bay Rd in a new Celica.
