  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
LAST DAY!! :(
Man there is some really bad phucking karma floating around lately and its got me a little worried ....... saw a truck rear ended a Toyota Echo hatch (and we all know how tiny those things are!) on the way to work. Looks like the guy will be ok .....very lucky. In the last week ive seen about 4 different accidents with my own eyes only one fatal .... but thats usually a lot more than i see in a year!!
no dickhead panel beater has ordered n fitted them already ..... complaining it cost him $65 :( ..... i counted the weeks its been there last night .... and it was exactly 6 WEEKS .... 6 WEEKs and he's proud of himself because he just fitted the phucking mesh yesterday!! THAT SHOULDVE BEEN DONE 3 WEEKS AGO!!
ahhhh calm blue ocean, calm blue ocean
It will have to go back to have wing fitted cos its still on order *cringes* not looking forward to my baby going back to that place ...... probably never to be seen for another three weeks!
