  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Lee i feel physically ill cos my dad is really stressed with his bizness yet this time everyday i ring dad to ask how its going only for him to get in a huge fight with the panel beater and become even more stressed and me to get disappointed. :(
One Saturday afternoon, I was sitting on my front door step, drinking a beer and watching my girlfriend mow the lawn. The lady from across the street was so outraged at this that she came over and shouted at me, "You should be hung!" I smiled and calmly replied, "I am. That's why she cuts the grass".
