  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by gen180
hah! must be an ex Trev. a bit like the skylines with monster tacho's and shift lights and the only mod is an exhaust
Yeah bit like 180's where their only mod is a giant blow off valve :D
sorry just had a few teeny boppers in here lately that are more interested in rice than performance .... it gets annoying with all the questions about neons and gauges and paint jobs :D
Since 1912 the spark ignition internal combustion engine's compression ratio had been constrained by the unwanted "knock" that could rapidly destroy engines. "Knocking" is a very good description of the sound heard from an engine using fuel of too low octane.
^maybe Adrians knocking sound is from dirty fuel?
To obtain the maximum energy from the gasoline, the compressed fuel-air mixture inside the combustion chamber needs to burn evenly, propagating out from the spark plug until all the fuel is consumed. This would deliver an optimum power stroke. In real life, a series of pre-flame reactions will occur in the unburnt "end gases" in the combustion chamber before the flame front arrives. If these reactions form molecules or species that can autoignite before the flame front arrives, knock will occur [21,22].
Not if you are meeting the octane requirement of the engine. If you are not meeting the octane requirement, the engine will rapidly suffer major damage due to knock. You must not use fuels that produce sustained audible knock, as engine damage will occur. If the octane is just sufficient, the engine management system will move settings to a less optimal position, and the only major penalty will be increased costs due to poor fuel economy. Whenever possible, engines should be operated at the optimum position for long-term reliability. Engine wear is mainly related to design, manufacturing, maintenance and lubrication factors.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
