Alex .... now what am i going to do with 400rwhp? haha besides .... i cant afford to break stuff .... i had a friend that modded his WRX to an unbelievable ammount of pwoer and he just kept breaking it so he sold it an bought a mercedes haha :D
Yeah well im going to need all the help i can get.
Q: Will i hit the speed limiter down the 1.4?
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
not much at all - but it always feels like it doesnt take that long to hit 180. Not that i do it often :Parnoid:
I guess the road looks a lot longer when your spectating than when your barralling down it at 160 :D
