  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah store manager not much of a store manager today anyways
thats enough about work
back to choosing colours for dans super cool actuator
hmmmmmmmmmz wat about bright orange? then u could say ur turbo is so powerful it makes the actuator glo bright orange
adrian :cool:
haha dan ate all your crayons hey? well just use some oil pastel's or they gone too?
and remember just stick the actuator back on with clag glue, as long as you haven't eaten that too :cool:
hehe ralph from simpsons
"umm, excuse me Miss Hoover, i ate all my glue":bahaha:
adrian :D
