  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah i probably wont actually get the SAFC II installed and tuned til the FMIC goes in ;) Do it all at once!! :)
Looks like all my friends are getting "tightarse Xmas" this year ......*better start swiping some stationary before i leave today* Mum ..... here have a pair of scissors for Xmas .... and Dad heres a stapler ..... Mel you can have a highlighter :)
mexr .... you religous ... tell me to mind my own business if you like ... its just most of my family of JW's and dont celebrate it either ... so really i only have to buy for mum n dad. :)
Fane .... sounds serious :) ... you going to use it for track work?
you can still tune your engine much better with an safc mex.... :)
i can see it helping heaps because the NA relies on good tuning so much.... all your Air/Fuel mixtures can be perfect...tuned for all your mods like exhaust and pod and shit.... as you get more you can forward the timing etc etc.... :) i can see it helping...
haha going to buy a big arse turbo Fane? Nah well mines auto so i cant have over 300rwhp anyway without going and replacing transmission with a hoity toity jap one .... which really aint worth it .... i just want a reasonably quick fun car .... but i just couldnt spend a huge amount of money on it - it would seriously make me cry the day you go to sell it and you've spent $10K in mods and only get $9k for the car haha :)
nah i wanna buy a play toy and make my GTST daily driver .... i so want an ferrari red R32 GTR .... oh yeaaaah!
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
