  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i though i a 50+ year old man would be resposible.... i guessed not
Golden rule my friend, dont share your bike to anyone, don't share your woman with anyone and above all don't give your car anybody!!!
who uses Macintossers these days anyway? :D
But i admit - this sucks bring back old skool forums!
Another Sunday night job searching ..... although found something that takes my eye :headspin:
that is nice to see... what are you actually looking at
Administration for the marketing department of a Software company .... they need someone to feed the fish apparently :D .... haha but nah looks like from the description it would be a good job so i might send off my resume tommorrow :)
just thought i'd share my experience with you all .. if you EVER think you have a bad day, think of mine today:
Woke up, hung over, feeling like shit. Both the g/f and I spewed pretty much first thing.
Got dressed, BIG MOTHER ****ING spider on my shorts. Killed it.
Most of the day went pretty well from then on in until ..
around 6pm, I thought I'd go for a bit of a spin, check out the sunset and just have a good drive.
Get to the garage, no keys.
Check with the g/f, she has no keys.
Spend 20 minutes bitching. Spend 40 minutes trying to climb up two levels to our apartment. Spend an hour waiting for the locksmith we called. Spend 45 minutes trying to pick the front door lock. Spend 10 minutes on the complex back door lock so we can get to our apartment door lock. Neighbour yells at us, lets us in the complex back door, spend 1 minute picking apartment backdoor.
EDIT: Forgot to mention, cost $140 to get him to pick the lock! :)
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
