  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
:grouphug: uneekwahn ..... we've all locked ourselves out at some stage! Luckily where i lived in Como there was an Alleyway behind us just jump the fence there.
Sil80 yeah it does sound good - there isnt usually decent jobs advertised this year .....i loathe interviews tho!!
Hi ben :D
i though i a 50+ year old man would be resposible.... i guessed not
You ain't seen me drive then
* Note , This does not mean that gtrken is anywhere near 47*
Oops , did I say that?? :blast:
Cheers
Ken
ahh nizmo just take deep breaths all the way through and have a good night sleep the night before. being relaxed in there is the best method. i usually get haulled in the bossed office and asked why i should be working where i am and if i want something better i should explain to him/her (i varies) why :D
sileight making mental not not to let old people drive the car... older does not mean more responsible : :D
Cheers
Ken
hi dan, ken, paul ..... thought everybody would be watching 5th element.
Gday babe :D :headspin:
Nah , you seen one gorgeous , dumb blonde with a great body , you seen em all
cough* bullshit* cough.
btw , liked the pic in Perth Street Machine....
Cheers
Ken
hey ken :) so how long before a Ricey opening for Hyperdrive ..... gotta compete with the SR guys haha *jk* :D
Wen tto the newsagent saw the picture ..... wasnt worth buying the mag for :)
