  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
$5000? who told u that? man they must be smoking some good shit :D
don't ur wisdom teeth hurt still? if u didn't get em out? mine hurt every second day, so i bit the bullet and decided to get over my phobia of needles(which i never will get over) and put a date down to get the suckers out :)
it's the day after sunshine people as well
niz u coming to globalfest?
adrian :)
the bit i am dreading the most is the needle, after that it should be fyne
when i was lil, i had hepatitis b shot in my butt, but on the first go i tensed my ass cheek up and the needle snapped in half :) hehe my dad laughed so hard, even the doctor was laughin :)
adrian :D
nah mine dont hurt .... they do know harm so theres no reason to have them out in my opinion ..... its funny cos only my bottom ones came thru .... they wanted me to go get an Xray to find out where my top ones went too ... but i didnt have the time.
Nah not going to globalfest.
my best bud wants me to go to Perth Cup .... but i dont really wanna go .... it doesnt interest me .... only time i like ascot is Melb Cup .... last time i went to Perth Cup it was worst start to new years eve ever cos i had to be rushed to the emergency room and i had a boyfriend that decided that even tho i was really sick and had to go to hospital he would do a million other things befor ehe took me :D then wouldnt stay emergency room with me .... went and slept in the car the whole time. So yeah bad memories and i dont really want to go.
Never heard of sunshine people ..... sounds jamacian.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
