  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
it got stolen at least 6 months ago,
i got it back but had a fair bit of shit stolen including,
panasonic cd player
pioneer 3 way 6x9
mb quartz 6" splits
pioneer 4 channel amp
pionner 2 channel amp
rockford fosgate 12" sub
autometer monster tacho
autometer oil, water, volts gauges
i have been finding out information through people and have narrowed it down to 3 guys, first 2 guys i know where they live but the 3rd moved, now i have his address time to go door knocking :D
baseball bats with nails in em :)
gotta be ultra mob styles ;)
speaking of mobs have you guyss seen kill bill?
quentin tarantino makes some bloody good films, even though it takes him like ten years between each one :D
adrian :)
