  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
rev, it doesnt take 2 mins trust me, u got to boil the water -> then att noddles -> then wait 2mins for them 2 cook -> then add that chick stuff -> then wait like 1min -> then put into a plate -> then wait for them to cool down (2 to 4mins) -> then eat them so takes about 10mins to eat them
