  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hobby at the moment is finishing the unpacking and to clean up. Going to do some gardening soon... well troy will do all the hard work of course pulling out all the dead or tacky trees/plants that i want gone, while i sit back and encrouage him hahahaha ill do the fun stuff.. like the planting. I think its fun.. no idear.. never done it before.. Its just going to be hard keeting it alive. I bought some flowers for the frount garden a few weeks ago.. killed them in 2 days. Aparently it was the hot weather that did it.. thats what ill keep telling myself anyways.. IM NOT A PLANT KILLER!! :D
Yeah still working as a kindy teacher. The kids are being wonderful at the moment.. its just the staff are being petty idiots. Both my center boss and my state boss are on my side thats what counts. Work has offered me to work casual hours next year. Basicaly with the money i will get with centerlink, i can only earn a cetain amount before they cut payments. Work said they will employ some one that works around me. Say if i can only do say 3 to 6pm, the other person covers the rest of my normal 8.5 hour day. So i just work as many hours as i can untill my centerlink payments are cut down.. and then i stop because its not worth it if they cut my centerlink payments down. Im lucky they are doing this for me. Troys moving in also before i start uni (hopefully) so ill be fine for money. Its not like im used to having lots anyways.. all of my money at the moment goes on bills.. i should actually have some money to play with when troy moves in and im at uni.
moving is deffently not cheap. Bond, rent, etc etc.. you need at least a grand for a normal priced place.. then if its not a furnished place.. thats more money.
I have a washing machine for sale though ben, if you need one when you move :D cheap only $50! Twin tub... really easy for a bloke to use.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
