  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Where a buck's enough to see their stuff, at the nudie bar.
Where the breasts may be fake but man do they shake, at the nudie bar.
Where you swear like a sailor, and wish you could nail her, at the nudie bar.
Where the cops are at the door, and there's a Kennedy on the floor, at the nudie bar.
1. It's okay to call hooters "knockers" and sometimes "snack trays."
2. It is wrong to be French.
3. It's okay to put all bad people in a giant meat grinder.
4. Lawyers: see rule three.
5. It is okay to drive a gas guzzler if it helps you get babes.
6. Everyone should car pool but me.
7. Bring back the word "stewardesses"
8. Synchronized Swimming is not a sport.
9. Mudwrestling is a sport.
Ok, mus finish my assssssssignments ....
Talk later :)
Where Christmas is nice, and lap dances are half price, at the nudie bar.
Where you drink down the shooters, and unwrap the hooters, at the nudie bar.
Where eggnogs are plenty, and the girls all twenty, at the nudie bar.
    • You need one of those automated sprays that puffs a nice small every 15 minutes in their room. Except swap the nice smell for chloroform...
    • Don't step down power supply size, maintain it the whole way. It's how I'd do it. OR, Id have one feed, with one joint that splits out to six smaller gauge wires that go to each coil. I wouldn't add joins like stepping from 12 to 16, at the first two coils, as if you try to continue that fashion, each joint will introduce a voltage drop. In theory, earths should be the same size as power feeds, however in this case the main power needs to be bigger due to the average size current. So the next question is, how much current do these coils actually need?
    • I think Murray is onto it. It's sounding like either it's a soft block, not long enough block, OR if you're chasing waves, you're going in the direction of the waves, instead of across them. Rotate your sanding pattern by 45 degrees is something to try. You said you're going in an X, so now instead, from the same perspective, do a "t" instead.   If you're not able to have the block sit on top of two high points, and not touch the low point between them, you'll never get it flat.
    • Hi, i’m making Vag coil loom for rb25det, can anyone confirm the wire guage i’m using for power supply in diagram is enough for supply not too small for loom? For earth do i need to follow the same procedure or i can use only 16awg wire for all coil and their connecting wire following to the plug?
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
