  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
well i think im quite decent in the driving area ... come for a hills run in my current race spec stock as a rock vn and it will show ive got at least guts :D
all i know is i like to drive on the limit and im not afraid to push that little bit harder...... might be a good idea to do this and see how i go
Race spec stock as a roc???
Prease exprain???
No VN I know goes around corners... :) Hehehe
Cheers
Ken
avoid the hill climbs for a while then, they hurt if you pusht he limits that bit to much..
Heheheheehehe
I gotta admit , the Meelup hillclimb had me clenching the buttocks...
Jill ( red 200sx) promised that she would not return to her scene of carnage :D
Cheers
Ken
are hill climbs any worse then say a 1am run through mundaring weir road ?
Mundaring is a nice road but the trouble is unless the clock is on , you are only racing yourself.
When the big boys come, you realise you were only playing....
PS I am not saying I am a big boy ( cosa the wifa says I ain't) but a until you give it a go , you will never never know... :D
Cheers
Ken
well Ken i simply just line it up through it in and steer her through and shes stock as can be - last g3wc cruise i paced 3 ls1 powered  commodores with brakes smoking by half way.............
Tom , you have got to be kidding??
Tell you what , I will take for a run around Collie or wanners next year.
Don't want to be rude but when you are starting to get flat 67's long circuit in a road car then I will start to worry.
I don't want this to sound big headed but a lot of people think they are going quick until they go with someone quick.
Try going with Denver on a drift session or Brett Morse in a 2wd BMW against my old GTR and finishing poofteenth's behind. Man , that boy can drive..
Cheers
Ken
Oh now doubt Ken ive never been on a track before where u need to know how to really drive....
personally however ive always felt like i know how to push a car hard - its my pashion to drive cars and drive em hard.
"you have to be kidding" - almost the same thing the owner of one of the cars said to me that night :D
Tom , don't get me wrong , I am not knocking you.
It's just that every young person who comes to me seeking training/guidance/insparsation/encouragement thinks they are the next Colin Mcrae/Michael Schumacher/Denzo.
They think that they are the best and what they have done is unique.
I can tell yo that I did not invent it and am not the best , but neither are you.
What I am saying is that with age comes experience and knowledge and I can tell in 10 minutes if you *have it* or are just like a lot of the rest of the young people that think a power slide is actually drifting and an apex line is something that a drunk chick gives you...
Cheers
Ken
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
