  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
what is with me today? i kept dropping stuff and knocking my toes .... & it phucking hurts! stoopid big feet!
its fair height too... gravity acceleration!!!
The standard formula for gravity is:
Gravitational force = (G * m1 * m2) / (d2)
where G is the gravitational constant, m1 and m2 are the masses of the two objects for which you are calculating the force, and d is the distance between the centers of gravity of the two masses.
G has the value of 6.67 x 10E-8 dyne * cm2/gm2. That means that if you put two 1-gram objects 1 centimeter apart from one another, they will attract each other with the force of 6.67 x 10E-8 dyne. A dyne is equal to about 0.001 gram weight, meaning that if you have a dyne of force available, it can lift 0.001 grams in Earth's gravitational field. So 6.67 x 10E-8 dyne is a miniscule force. When you deal with massive bodies like the Earth, however, which has a mass of 6E+24 kilograms (see this Question of the Day), it adds up to a rather powerful force. It is also interesting to think about the fact that every atom attracts every other atom in the universe in some small way!
cheers
JOe
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
    • planning a r34 rb25 de+t with some other work, rather just have it done in a shop due to space limitations any recommendations? I have most the parts already I seen online Moore Performance and DR Drift any advice appreciated thanks
    • I’ve read the previous posts so just looking for latest information on how people have dealt with front facing plenum is it a defect etc or didn’t pass roadworthy or was it not noticed? Have a r34 and deciding if I should make a hole on the driver side or not.  I know some people have said blitz return flow but I might get rid of the stock intake down the line for a plenum so I rather set up for that now plus I already have a standard Intercooler. Car is mainly stock  Thanks.
    • Actually, if having and keeping the stock ECU is the plan, the correct answer is to put Nistune into the ECU and improve the situation, not just look at it.
    • Wrong side of sydney for me coming from Goulburn, but you should head along, all ages of Skylines will be very welcome
