  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
what is with me today? i kept dropping stuff and knocking my toes .... & it phucking hurts! stoopid big feet!
its fair height too... gravity acceleration!!!
The standard formula for gravity is:
Gravitational force = (G * m1 * m2) / (d2)
where G is the gravitational constant, m1 and m2 are the masses of the two objects for which you are calculating the force, and d is the distance between the centers of gravity of the two masses.
G has the value of 6.67 x 10E-8 dyne * cm2/gm2. That means that if you put two 1-gram objects 1 centimeter apart from one another, they will attract each other with the force of 6.67 x 10E-8 dyne. A dyne is equal to about 0.001 gram weight, meaning that if you have a dyne of force available, it can lift 0.001 grams in Earth's gravitational field. So 6.67 x 10E-8 dyne is a miniscule force. When you deal with massive bodies like the Earth, however, which has a mass of 6E+24 kilograms (see this Question of the Day), it adds up to a rather powerful force. It is also interesting to think about the fact that every atom attracts every other atom in the universe in some small way!
cheers
JOe
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
