  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
what is with me today? i kept dropping stuff and knocking my toes .... & it phucking hurts! stoopid big feet!
its fair height too... gravity acceleration!!!
The standard formula for gravity is:
Gravitational force = (G * m1 * m2) / (d2)
where G is the gravitational constant, m1 and m2 are the masses of the two objects for which you are calculating the force, and d is the distance between the centers of gravity of the two masses.
G has the value of 6.67 x 10E-8 dyne * cm2/gm2. That means that if you put two 1-gram objects 1 centimeter apart from one another, they will attract each other with the force of 6.67 x 10E-8 dyne. A dyne is equal to about 0.001 gram weight, meaning that if you have a dyne of force available, it can lift 0.001 grams in Earth's gravitational field. So 6.67 x 10E-8 dyne is a miniscule force. When you deal with massive bodies like the Earth, however, which has a mass of 6E+24 kilograms (see this Question of the Day), it adds up to a rather powerful force. It is also interesting to think about the fact that every atom attracts every other atom in the universe in some small way!
cheers
JOe
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
    • @GTSBoy iam not a mechanic so what could typically gone wrong? It can help my mechanic...maybe he just forgot something or something like that that could help. Yeah i thought. I took a LONG time to search for the right one. Yes i read about all of that and i give him a call about that. I look at those slave/master cylinders and they are not that expensive so i will be buying them anyway just to be sure.   @DuncanYou think it can be short? I double checked if that was a right one(it came with the clutch kit) Ok i will give him a call. Hope it is some sort of "little error" and not some "yeah the gearbox needs to go out" one
    • Temporary. Sorry about the inconvenience while we sort some issues.
