  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i thought it was joe spouting scientific crap again .... am so natural blonde .... you seen pictures of me at home havent ya? But im not this blonde naturally .... i was until about 11 then it went a bit more of a dirty blonde.
Dads not as tall as me either :) i wouldnt mind being tall but not this tall!
how can people eat muffins? .... i had to grab something quickly this morning from MYO and they didnt have all their sandwhich stuff out yet so i grabbed a muffin .... but they are just like a big piece of cake ..... and im not a big cake eater .... just taste of flough n dough n a bit of fruit.
mum cooked a big t-bone last night ...... but i couldnt eat it all .... it was so yummy but i could only eat a 1/3 of it cos i hadnt eaten all day ...... and you'd think i would be really hungry but i cant put real heavy stuff on an empty stomach ... just makes me feel sick.
i love roast silverside with hot english mustard spread on it and roast vegies :drooling: .... they are pretty easy to cook so i might have to grab a couple to cook while my folks are away.
9:30am work til 5:30 tho
sounds good Lee! :) got room for one more? *jk*
My folks n I are having our Xmas lunch at a resturaunt tomorrow also the "giving of the crappy presents" cos they leave on Sunday for sunny tazzie
last year they went to Adelaide :confused: im like yeah you have Adelaide..... i went off to the Gold Coast :)
they pick the most boring places ..... but they are food n wine people
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
