  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
norfolk ..... nah its not my scene there .... last time i went there with Liz my feet got trampelled on and there was some pretty dero looking people.
TJ, Ant, Ross, Simon and a few others are going to Glocester as well .... they asked if you were coming.
lol .... yeah mel n i might sit in dirty nellys for a while and get a head start :( .... oh well its either that or paying a fortune in Taxi Fares :P
I really need to move closer to the city.
last time i asked you to pick me up from a horsey event you were in such a foul mood i thought i wouldnt risk it asking again :(
havent looked this morning i went shopping with my monoply money .... hats are phucking expensive!
good way not to get burnt .... lol im going for the practical reason this time. Im not really a hat person either but i couldnt afford a new dress so i thought it would also make the outfit i got look a bit more dressy.
i dont like to upset you :( i dont do it on purpose - just when it happens you kinda need to take me aside and tell me what ive done so i know. :P
Well if you still want to give us a lift you can cos i would prefer to go later but if not thats no problem ... id imagine its a bit outta the way.
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
