  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
man
i've been ripped off by some a$$hole on ebay.
got a phone from him, its the wrong color, its scratched and it was locked to a .uk network.
I sent him an email and he's offered to pay me $30 back, but I'm going to ask for $100 so I can buy a cover to make it the right cover.
Anyone else had bad problems from ebay?
