  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yay an ex burning session ...... lol your going to need quite a bonfire with the stuff from my ex ...... my 19th birthday a van had to deliver all my shit at work ..... the van was half full with stuff he bought for me ....... lets just say when my ex did something it was extravagant. LOL best one was when at my last day at a job i hated he got flowers deliver for me and on the card he wrote "phuck them all" .... and i was laughing so hard in front of everyone when i read it they were all "oh isnt that sweet flowers.... what does it say on the card" ...so i told them .... they werent impressed.
lol my ex was master of mind games .... he used to boost about it. One of the last times after we broke up and he came n met me for lunch still he was going on "Everyone thinks im a phucking legend cos i make them think that .... im going with this chick to the ball .... dont even phucking no why i invited the bitch i dont even like her but she'll make me look good"
Everything was about appearances to him .... after that convo i was like .... im so not sorry i got rid of you what a wankker.
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
