  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
you wont get banned but you'll get done for false advertising when you start getting PM's from people wanting their car cleaned :D
Hi Tom :wavey: you over your little tanty a couple of nights ago Re: Commodore?
Bye Bye Aidwin.
I have bug to spend money on my car ..... parents will kill me as they want me to save but theres too many ideas ticking over in my little brain and i cant leave it stockish! Ive actually decided i dont like the inside ...... im actually considering after the performance side is done to get leather interior .... even tho is sticks to ya arse when wearing a skirt. Im thinking im going to go for black n white leather.
LOL @ SAUWA Bikini wash
i know its ricey .... but the dark blue plainess is really starting to piss me off .... outside looks mint .... inside looks drab .... redecoration here i come
