ken, how can i fix it? wat tools would i need and also wat materies?
price am i looking more than $500?
What ,for that little crack in the lhf on the bottom.
I think yours is fibreglass in which case some fibre matting at the back for some strength , a bit of resin, sand it down and try and find some touchup paint from Auto one thats close.
Prolly about $60
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
ken, i think it will be more than that, cuz the crack is pretty big and it also has a crack half way up on the left side :) i will just take it 2 a shop 2 get fix, then take it 2 get respray.
and yeap it is fibreglass, i dont wanna replace it cuz there is only 1 other car in perth with the same kit
heya denver
aidwin youve got a yellow :) on 33 lol
Mr Ken im still a hyperdrive virgin - blame the 30
yea , noticed the lack of TomJ last Friday...
Ahh well , drop past whenever but we are getting bloody busy atm.
Hate to see what it's gonna be like when the dyno starts running....
Cheers
Ken
how did my car look tom? oh i miss it so much.
Steve will get it to full power again soon so cant wait
Aidwin , when you taking it back to KL?
I thought the import duties and taxes were exorbitant/
Cheers
Ken
Might call in and have a chat next week Ken ... Need some cars tuned in the next month ...
Holidays  :)
Yep , no prob but make sure you say that your dsturbed off the forum.
Not looking for some part time contract work by chance, especially if you can build manifolds, exhausts, pull motors and boxes in and out ??
Cheers
Ken
ken, wat where those places for the bodykit shops?
read back and the yellow pages is your friend.
Spoiler Shop in Myaree
GFX body kits which is part of Master smash in Trugannina rd Malaga
Cheers
Ken
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
