  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i dont flirt with cops - had one flirt with me but it certainly wasnt being returned ..... im friendly but no way do i flirt! Im even truthful with them when they ask me why i was pulled over.
i nearlylost 6 points in one hit .... i was told i was losing 6 points .... but at the end of the day they walked away muttering they had something better to do ..... ahhh i dragged an unmarked cop car and got away with it :wave:
