  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
I'm back from my afternoon on the river .
Coolcruise in the Bayliner 23 from Guildford to Matilda bay for a picnic tea and a few beers , then back to guildford , on the trailer and home.
As I was sitting out the front, cool breeze blowing and skimming across the Melville waters millpond is was thinking
* I wonder what the plebs are doing *
Now I know , breaking sumplugs , back windows and getting hot.
Hehehehe
Cheers
Ken
mostly stuck in garage - its quick but handles like a dinosaur - a dangerous combination! Its dragged a skyline and won and i reckon that my skyline is probably slower but my skyline is a lot safer to handle. Nearly ended up being my coffin a couple of times - incuding once loosing control and almost becoming truck food!
mmm yeah a lot rarer than the 180 - i had a choice between the 180 and my Z31 - and i just fell in love with my Z31 and that was it! But its rare to see ones in that condition and ive only seen one other black one around - the guy that owned it bought it out from hong kong in 95 owned it since new - he now drives a line that looks a lot like mine but can shite all over it with the amount of mods he's done (he's about 60 its really funny lil boy at heart me thinks) he was there when i went to pick my line up!
Hes done a few useless ricey things to that ZX such it beeps when the break pads are low haha
Originally posted by GTS-t VSPEC
Ken,
Your a bastard!
Scoring more brownie points with the Mrs?
I feel sorry for Micko. just when things were looking up. Do you have a rear window for him?
See'ya:burnout:
Stuff the brownie points , I wanted to do it and she was happy as well ( double bonus )
wtf did you do to Mickos sump plug ??
Cheers
Ken
Guest
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
