  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Ken,
I know alot of people who want to kick his ass, but I don't have the budget to do that. I just want to take my fully modded street car and race it.
See'ya:burnout:
well forget getting more power.
Go for the biggest badass son of a bitch they stop , mother fu**er brakes on it and strip the car.
ANY road car using road type brake rotors and calipers will not last 6 hard laps around there.
If it does , yo ain't trying hard enough boy !
Cheers
Ken
Ken,
If you were her father, then I bet she thanks god she looks like her mother:p
See'ya:burnout:
well thank god I'm not her Father cos it would be incestous thoughts not just dirty old man thoughts.
Hehehe
Cheers
Ken
ps Just kidding loz , really . Would treat you like a daughter, honest.:P
I have the option of buying R32 GTR brakes, don't know if they are worth it.
See'ya:burnout:
Ahh you have 4 spot 296x28 mm rotors on the front of yours.
R32 gtr have 4 spot 296 x30 mm rotors on the front.
The gain is ?.......
Cheers
Ken
I have seen a set of 8pot Brembo brakes, I think they would do the trick, tied with some 360mm disks:p
See'ya:burnout:
NOW ya talking.
Trouble is can only go up 1 inch on std size wheel so 360mm are a bit tight.
But you are getting the idea. must get the ones with no dust seals or will set fire to them ( I did )
Cheers
Ken
Cheers
Ken
2mm paul only wishes he could get an increase like that where he needs it.
:P hehehe
They are cross-drilled? So not much point. I'll have to buy some decent 6pot AP's, don't want to sell me yours?
See'ya:burnout:
crossdrilled for racing is crap.
Stress heat cracks start from the holes and run to the outside very quickly.
In fact I don't know why they cross drill discs?
Cheers
Ken
Guest
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
    • Gee she looks a bit rear heavy in that first pic! Sounds like a great project with the kids, but as I guess you know R series stuff is getting hard to find and pre that is pretty much impossible these days
