  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
On a non sex related subject remember how yous told me 2 buy a turbo? well i thought if im gona get a turbo i may as well go all the way so im gona save up 4 a r34 instead cos 33s r gettin really common and there r hardly any 34s so i reckon bout 2 years ill hav saved up enough maybe less than 2 years at the rate i wrk - being a workaholic!
Originally posted by GTS-t VSPEC
Ken,
You didn't answer my question last night. Do you have the torque figures for doing up the head on the RB20?
See'ya:burnout:
No , I went to bed cos you were all boring.
Talking about cars and stuff.
Why , you gonna help Adam 32.
Can check but only have specs for RB 26.
Ohh and check your PM.
Cheers
Ken
In 2 years time R34 's will be common
Cheers
Go the 32's
Ken
Originally posted by Nizmo
betty is easier to find hehe.
ooooo relationship - thats a very big word for a guy haha.
might have to go to bed soon im not very well - need male nurse *batters eyelids at paul*
What , more Battered eyelids.
Who keeps hitting you ??
We will kill them won't we pwpt60secf:D
Cheers
Ken
yes in two years time we can all upgrade :D but for now im very much attached to whats under the carport it keeps me broke enough as it is.
Can't be too attached , your trying to boot the Z out. Hehehe
Cheers
Ken
Yeah, checked my PM *keep it secret, keep it safe*
I think they are all the same, but don't know for sure.
33Spec2, Start saving, nice cars, but I'd go for an R32 GTR:p
See'ya:burnout:
If you are going to then PM her ( no , not you Loz )
:D
Cheers
Ken
easy to personalise - see a few R33's but the only time i see any like mine is when i cruise with you guys and theres 4 cloned black ones all in a row - lucky for me theres only four other people dumb enough to buy black haha
im not trying to boot Z out my folks are :D mum cant get to her porsche with it in the way - but that gets driven as much as me Z anyway - its a convertible so she leaves the roof off for all the spiders to inhabit and the rain to blow in hmmm not the smartest move.
Guest
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
