  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
The sony players aren't too bad, not 'A' grade, but then they aren't 'A' priced.
The same mpeg boards are found in the cheap ass DVD players. There is a singer unit (in the cheap ass range) that is probably the best of a dodgy bunch (rick heart has them last I checked).
rev210, things would get a hell of a lot better if the americans would recognize true black to be 0IRE instead of whatever the hell they think it is (7.5 issit?).
adam 32, you enjoy playing region 1 discs on your Sony? I don't think I've heard of a region free model by them. Ever. And mods are expensive too. I'm not a Sony head so don't hang me it their latest stuff can do it :)
evening all..
got zanda's turbo off.. found the problem with the turbo/manifold gasket.. it's missing one of the 4 nuts holding the turbo on!! not quite sure how it would've come off cause there's a tab washer there stopping it? also the other 3 nuts were like finger tight?
wierd!
Originally posted by Pva_Glue
I just had crazy thought when I red your reply...
Why Oh Why can't I do that with WOMEN :):D :bahaha:
smart arse.
Because we pick you - you dont pick us :) We have the power well thats what you learn when you watch the discovery channel -
thats why males are programmed to bonk almost anything while females are a little fussier who they mix their gene pool with.
Wish troy was here - he usually a wealth of info on this stuff :)
Originally posted by macka
rev  u dont need it chipped to play dvds? do u?
The PS2 plays DVD's just not multi region without a mod chip. Put the chip in and you can play multizone (read pirate) games too.
The mod chip for the PS2 is not very expensive.
The PS2 enables you to play GT3 and race mines GTR's around.
Guest
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
