Item:R32 Gtr passenger seat with rail
Item Condition:Excellent (no stains, tears or burns)
Reason for Selling:No use/need cash
Price and Payment Conditions:asking $400ono
Extra Info:buyer pays for postage, pickup available
Contact Details:pm via forum or post in thread
Passenger seat out of my gtr.
Pictures available upon request.
Edited by «Cyph3r»
https://www.sau.com.au/forums/topic/88442-r32-gtr-passenger-seat-for-sale/
have you got pic?
send it to [email protected]
have you got both front seat s?
Only passenger side seat.
I will take some pics tomorrow for you
Cheers
Jamie
pics
Russell GTS-R no idea on postage sorry.
i'll see if i can get an estimate though it will probably take me a while.
pretty busy atm.
That'd be great man.
I'll keep an eye on this thread then.
I've bought a GTS-t that is hot as but it just has standard seats.
GTR seat would be great.
Would you take $350 including freight?
thanks,
Russell
Edited by Russell GTS-R
thanks,
Russell
No sorry 350 including frieght is too low.
I would be willing to go as low as 350 + frieght or pickup.
Fair enough. Is the only difference between the passengers and drivers seats the rails they're mounted on? ie: Would my drivers GTS-t rails bolt up to the GTR seat and fit in my drivers side?
thanks,
Russell
thanks,
Russell
Unfortunately the seats themselves are different as they have the back angle adjustment lever on the outside so if you switched rails (i'm not even sure if you can do that) the lever would be up against the trans tunnel side and awkward to get to.
Cheers
Jamie
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
