  • Replies 134
Thats probably when they'd get the most attention from cops with few people on the road.. I doubt anyone that would steal a line would do anything other than keep it garaged for a while/out of sight while stripping parts etc.
Indeed hopefully it was stolen by joyriders... best possible outcome is that it is dumped in one piece.. my old car had bugger all petrol and was stolen from flinders st bridge (of course), ran out petrol and dumped in melton after being driven into a carpark pole? and driven across a meadow? or some such.
Have you posted to Nissan Silvia or toymods at all?
Nissansilvia- YES
What Toymods? another forum? address?
Cheers
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
