Not sure how you clean metal mesh filters. I would presume you just spray them with some sort of mild solvent (contact cleaner maybe?) or soak them in something for awhile then wash them out and let them dry.
Any metal mesh filter experts around? :) Either way, they don't need oiling. And because you say it's metal, I'm pretty sure it's a Blitz (could be wrong though)
  • Replies 50
If you don't oil it then it will just let through the smaller particles of dust. Which may not be that bad if you don't drive through any particularly dusty areas, but keep in mind that even when oiled the HKS filters let in a fair few particles of dust. They're designed for the track, where dust and engine longevity usually aren't of much concern.
That said though, I bought my car with a crappy unoiled Redline pod filter which you could actually SEE gaping holes in, and I don't think the engine is any worse for it even though it was a couple of months before I got my Apexi pod. But then again, I never made a habit of driving it through dust storms either :)
INASNT, all I can say is don't believe everything you read. I read that article too and that's why I bought the Apexi. But after I installed it, the Apexi seemed to be more restrictive than the old HKS I had borrowed off a friend. The car had noticably less up-top than it did when I had the HKS in.
Once I installed the cold air box this got resolved and I couldn't tell any difference between them, so I think just by design the HKS will suck in less hot air from the sides. So I'm thinking it has a better ram air effect than the Apexi, and if you don't have an air box/don't want one/can't afford one/whatever, the HKS is probably a better filter to buy.
I know enough about foam filters (ie, crap at filtering) to believe their filtration test results though, which is the main reason I bought the Apexi.
mm2 death: you must oil the k&n filters after you wash them, they filter much better.
ive got a puple HKS filter on my 180sx, it came in with the car and its half purple half black, so i must wash it right away and oil it.
i beleive there are a few different colours with the hks; green, yellow, red and purple.
ps- so whats the best stuff to use when washing the hks; soap n water then oiling, or degreaser and then oiling???
the previous owner fitted the APEXI pod on my car, its due for a clean I was going to rinse it degreaser, fresh water and use the K&N oil even though its a mesh filter. Had a mesh K&N air box filter on my previous car and this worked fine
Jimx whats the deal on this cold air box, simlar to a factory air box or is a heat shield for the pod? how much and where ? keen for cold air induction and a factory non defect look ....
The Apexi pod doesn't need cleaning, or rather can't handle it. I think it's generally advertised as lasting forever, but I would probably replace it when it got too dirty.
I got my cold air box from UAS, it's just a partition with a lid on it. Looks really nice though, worth the money I reckon (about $180). The only problem with it is that it doesn't have a scoop or anything. I'm thinking of cutting a hole in my panel and running some PVC tubing down to the front guard. Just need to get motivated :D
i cleaned my POD filter the other week with the K&N recharge Kit! what a big difference it makes to you r car. I also changed plugs too. The thing is running ever so sweetly now. Full wheel spin off the gas on low boost (7.5psi), no clutch.
THe weather in Petrh's is a bit hot lately to run high boost. can't wait for a cooler day/night....
Originally posted by INASNT
dont spend $180 on a UAS 1, u can make your own 1 for a quarter of that!
Yes, but it takes time and probably won't look as good. How much is a weekend's worth of running around securing materials and drawing up plans and building worth to you? To me it was worth about $180 :D I knew there were plans for it lying around, but I cbf'd making one myself. I installed the box myself, that was enough of a challenge :P
I'm even considering getting the Hills Motorsport aluminium one at some point, it costs around $400. Might wait until I can afford all the hardcore stuff at once though.
What is the Hills Motorsport box?
Since you've already paid $180 for the UAS and are wanting this aluminium one costing $400 i'm guessing it is an upgrade.
I'm getting a FMIC in 2 weeks and already have the above mentioned mesh POD, should I be looking at the Hills box or the UAS one? I'll be running 1bar or more boost if that is a variable in this equation.
Thanks Jimmy,
Mark
Yes, but it takes time and probably won't look as good. How much is a weekend's worth of running around securing materials and drawing up plans and building worth to you? To me it was worth about $180 :D I knew there were plans for it lying around, but I cbf'd making one myself. I installed the box myself, that was enough of a challenge :D
Well i didnt make mine with the lid coz my pod was 2 big to fit in the box with the stock IC piping.
I paid about $40 for material and on a saturday i enjoy doing stuff to my car! :rolleyes: So i saved quite a bit! Did the UAS box fit perfectly? and do u have a fmic or the stock 1 still?
INASNT, The UAS one isn't a "perfect" fit, but it's better than I could do myself :rolleyes: I have FMIC. If you enjoy making stuff yourself then I say go for the home-made version. I just didn't have the time or patience to build it, though I do admit that putting the pre-fab'd one in was fun. I built a subwoofer box for my Commodore a couple of years ago and that was "kind of" fun, but I think this time around I'll pay someone else to do it :D
MRK25T, the Hills version is a proper sealed box with a bottom as well rather than just a partition with a lid. It's aluminium rather than fibreglass and hella sexy. It's probably not worth the price difference based on performance improvement, but the Hills one looks better (IMO) and is of a better design. It's up to you which you prefer and how much you want to spend. I don't know if I'll ever get it, it's something that I think would be nice to have but the UAS fibreglass one is good enough for now.
I was going to refer you to my original thread about it, but since then I've moved the pics out of my webspace :rolleyes:
I don't have any pics of the box here at work, I'll put some up when I get home.
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
