hey guys
my car stands
122rwkw
auto completely stock 16.1
auto
FMIC
10psi
AVCR
166.9rwkw
CES front dump pipe 15.2
Manual conversion
highflow cat
tuned at fist
170.1rwkw ( clutch slippin, was told by fist could of gone more )
back to 8psi 14.3
test and tune after 19th october <<<<<
turbosmart type 3 pb ( currently not plumb back due to autobarn f@#kin me round hang on ........ AGAIN!!!!
power fc install 19th october
Will see if i can put it back to 10psi
reason why it was put back to 8 was, it wasnt makin anymore power at 10
all times recorded were done on street tyres on 40psi
next time i go down after install of power fc will drop pressure of tyres to 25
Just gathering ppls thoughts to, what times would i be lookin at
when i get the power fc installed?
let yas know when i get it in and go down the track .
THanks
Barret
I'm guessing you drive an R33 right?
By the time you get your PFC installed and tuned, you should have something around 170-200rwkw depending on how much boost you run and depending on the dyno. I only mention the dyno because your previously quoted figures look a little on the generous side, but if all your figures have been done on the same dyno, then it's all relative so that's ok (BTW, what did FIST tune? You didn't mention that you had another programable ECU or an SAFC for example).
On street tyres, that should be good for anything from mid to high 13's (or even quicker with sticky tyres).
Good luck
what i was sayin was car completely stock ran a 16.1
the next lot of upgrades was
FMIC
10psi
AVCR
166.9rwkw
then next lot of upgrades
Manual conversion
highflow cat
tuned at fist
back to 8psi 14.3
first tune was at mercury motorsport , didnt tune my car !
2nd was at apc, which they apperantly tweaked the ecu abit
and did a poor job on my intercooler piping
3rd was at fist, which involved change timing, changed boost, as it was all over the shop , first run on the dyno tune b4 they touched the car was only doin 116rwkw.
once they tuned the standard ECU and changed timing and boost
it did 170.1
didnt mention that i had a programmable ecu because i dont have one !
standard .
And where is WSID, im in QLD i go to Willowbank raceway
thats if WSID stands for it .
FMIC
10psi
AVCR
166.9rwkw
Manual conversion
highflow cat
tuned at fist
back to 8psi 14.3
it did 170.1
standard .
Good luck at Willowbank.
it did 170.1
standard .
Don't think you can tune the Std ECU on an R33 mate...hence my earlier question.
Maybe check with the workshop and find out exactly what they did if you're curious. If the Std ECU was tunable, it kinda negates the need for the PFC then doesn't it? PFC will make a noticable difference in any case.
Good luck at Willowbank :P
yeah i might have to check what they did
cause i remember apc sayin that they could tweak the standard ecu abit
could of been something else though, who knows
whateva they did, they could of done a betta job.
let yas know what happens
thanks for the replies
  • 4 weeks later...
guys back again just got my install and tune of power fc
car is currently on 11 psi near enough with 187.6rwkw
power curve is real nice havent been able to give it a good go around
due to being wet
but next test and tune i'll be out there to see what time i can rack up
hopefully gettin into the 13's
let yas know how it goes
Barret
  • 1 month later...
Due to AFR's being real rich at 10.5, and timing a bit out from the tune at FIST
i have had my car tuned again at chiptorque ,
and needing a new o2 senser and spark plugs
got a result of 201.7rwkw on 12psi
After the tune of fist i did manage to go down the quarter and did a 14.089 at 101.69mph,
so will be good to see what happens now.
Cheers
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
