hey guys, all you 34 sedan peeps, how do you remove it?
i removed the two bolts on each side of the wing...but i cant budge it!...its like its bolted somewhere else... help me...
i have removed a 2dr spoiler...somehow that was way easier... i wanted to put that spoiler onto my sedan BUT I CANT FRIGGIN TAKE OFF MY ONE>..
any help please :O
https://www.sau.com.au/forums/topic/88712-34-sedan-spoiler-removal/
LOL yeh maybe it wasnt met to be taken out....
yeh i think double sided sticky but bloody hard it is...
i dont think its a slide and take off type spoiler... hmmmzz... try take urs out adam :O and tell me how you did it
The heating will only work if the double sided tape is rubber based... some of that stuff which has a layer of foam is impossible to get off. Trust me I know; my SAFCII had a tonne of it from the previous owner and I spent the good part of 2 hours getting it all clean :)
E_Lu_Shun - saw the thread re your SAFCII mounting... doesn't it get in the way when you're driving?
The heating will only work if the double sided tape is rubber based...  some of that stuff which has a layer of foam is impossible to get off.  Trust me I know; my SAFCII had a tonne of it from the previous owner and I spent the good part of 2 hours getting it all clean :D
You're heating up the adhesive, not the padding material. :)
The heating will only work if the double sided tape is rubber based...  some of that stuff which has a layer of foam is impossible to get off.  Trust me I know; my SAFCII had a tonne of it from the previous owner and I spent the good part of 2 hours getting it all clean :P
Nopes. Its just that if i want to use the heater..ill fold the safc2 down ;)
Thats the neatest place i could find to mount it
i was thinking about that earlier..but it didnt look that neat...if i had to make it neat..i would of had to cut the surroundings of the ash try to fit it.. btw if you have a Apexi ECV(EXhaust valve control) i have a mad place to put the lever....the cigarette lighter :P...i dont have pics of it, but will take some photos when i have to chance
dont do it elushun! leave the wing on! :P The shorter wing on the sedan complements the longer wheel base...I've seen the coupe wing on a sedan (black one like yours too) and it just ruins the sleekness. But each to their own I guess. Personally I'd either leave it on or remove the wing all together. Is tht a CF bonnet u have there???
HEy Ianh
The two plastic lugs that sit under the stand of each spoiler, is not on the sedan version...thats the problem.. its only on the coupe. With the sedan...its just two bolts on each stand.....nothing in between the bolts..I was thinking of removing to two palstic lugs when i put it on my car so it would fit.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
