What about shipped to erskine park near penrith?
Or is it not far for there...
Did doodz come and pick it up? If yes i will ask him
The same freight charge will apply
Kirrawee is a long way from Penrith
Cheers,
Steve
  • Replies 51
  • 1 month later...
Sure is mate, you can purchase online via our website by following the link below:
http://www.justjap.com/forumcoolerkitspecial.htm
Regards,
Steve
Hey Steve
i dont know if u can tell me this but ive bought and r31 passage with rb20det in it and im wondering would the r32 fmic kit fit correctly?
Hi Just Jap
i just wanted to know if the pipping for the r34 gtt is avliable, also wanted to know if the pipping follows the same way as the stock cooler??
or will it run on two different ends just like the sr20's
does anyone have any input about these coolers and pipping???
does it create any lagg, is the pipping 3 inch..
Edited by ZERO
  • 5 weeks later...
Another shipment of our famous intercooler kits has now arrived and we are now delighted to bring SAU members even better pricing on these complete intercooler kits!
Get in quick and pick up your Type 1 intercooler kit for only $499!
Order online now at http://www.justjap.com/forumcoolerkitspecial.htm
Cheers,
Steve
Just Jap
HI,
Nice kits you have there man. Just a quick question, for your type 1 kit for R33 Gtst and R34 GTT, are they the exact same....can you cross fit them?...if you fit the r33 GTST kit to a R34Gtt, will the piping touch the radiator fan?....hopefully u can help me here...thanks man
Hi 32Line: You are very much correct, the R33 kit and the R34 kit are the same.
Most kits tend to require some minor fan blade trimming, though this does vary from car to car.
Cheers,
Steve
Hi Just Jap.
SAME QUESTION AS ABOVE.
i just wanted to know if the pipping for the r34 gtt is avliable, also wanted to know if the pipping follows the same way as the stock cooler?? ( I have come across a Blitz type cooler kit that does this)
Hi Just Jap.
Hi Mike, I have replied to your pm.
The piping runs similar to the picture below, which shows one of our intercooler kits on an R32 GTS-T
some questions
- are the outlets and piping 3"?
- is the piping aluminium or steel
Hi mate, thanks for your enquiry.
The piping is alloy, and the piping is 2.5 inch
The coolers included with the kits normally use 2.5 inch outlets to suit the included pipework.
Cheers,
Steve
How much for the Type 2 Intercooler Kit to suit R32 GTS-T with delivery to Mildura, Victoria 3500?
Also, what's involved in terms of installation? I know it's not a simple bolt-on item, as the front bar needs to be cut into and I've even heard that the battery needs to be relocated.
I've got a huge battery, so I won't be able to turn it or anything to allow the intercooler pipe to go through.
Might have to get a SMIC... see how I go.
Thanks,
Adrian.
Thanks,
Adrian.
Hi Adrian, the piping that crosses over the front of the engine runs through the drivers side guard below the battery, so you should be able to retain your current battery.
Installation is more time consuming than difficult - A competant workshop can handle this side of things for you if you arent game to take the task on yourself.
We can have a Type 2 kit to you for $590 delivered.
Cheers,
Steve
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
